LT3092 is not function
The user asked about a circuit to maintain a constant current between 0.5-20 mA over a 0-2 kΩ load using a DAC. The final answer provided an LTspice simulation, suggesting the user check the pin numbering for the IN pin and connect the exposed pad to OUT. A capacitor from IN to OUT was recommended for stability.
Does this circuit work?  I don't know why the circuit I have drawn is not working.  I want to keep the current between 0-2 K load constant with DAC at the desired value between 0.5-20 mA.  I want to keep the current between 0-2 K load constant with DAC at the desired value between 0.5-20 mA.
