Given I am more of a digital engineer, I find myself challenged with an observation using the LT1573 to convert +5V to +3.3V. While trouble-shooting a design that nearly matches the first example application depicted in the part's data sheet, an inadvertent swipe of my finger across the circuitry caused the +3.3V processor to reset. I quickly ruled out a static discharge event. Upon closer inspection, I discovered how easily I can cause the regulator output to shoot up past +4.5V by simply placing my finger on the COMP input pin trace. Is this normal? My application does not need a super fast response time given there no major swings in supply load. All cases wherein the COMP input is unused shows it as a No-Connect, but trying this has the same effect. Could my issue be a component value error? Seeking advice on how to eliminate this unwelcomed sensitivity. Thank you in advance for any recommendation.
