Hi Belenie,
You could use a headroom below 400mV but that would depend on how much noise is going in to the ADP1741 and how much noise is allowed to come out of it. With low headroom the effective drain to source voltage of the pass element is equal to VDS = VIN – VOUT - VDO, this means that the pass element of the LDO is operating in the linear region instead of the saturation region and you effectively have a resistor that does not filter any noise in your input. Long story short, the lower the headroom the lesser is the filtered noise. However if you have a clean input for the ADP1741, you could run it below 400mV but we still recommend that you use the 400mV headroom.
Hi Belenie,
