Hi all,
This is an inquiry about how to use the LT3466.
I would like to use only one of the two channels.
How should I handle the SW2, Vout2, FB2, and CTRL2 pins that are not used?
Best Regards,
Thanking you.
Hi all,
Best Regards,
Thanking you.
Hi Takahiro,
You may leave those converter #2 pins (SW2, VOUT2, FB2 and CTRL2) open.
However, I recommend to use LT3465 instead of LT3466 if you are driving 6 or less LEDs.
Xian
Hi Takahiro,
To be on the safe side, best to ground CTRL2 to make sure the converter is off. Other pins can be open.
Hi Takahiro,
Xian
Hi Xian-san,
Thank you for your reply!!
Takahiro
Hi Takahiro,
