i try to achive -10V output following application circuit in DS page19. But my simulation output does not reflect correct output.
Can help me verify what's wrong?
LT8630
Recommended for New Designs
The LT8630 is a current mode PWM step-down DC/DC converter with internal synchronous switches that provide current for output loads up to 0.6A. The wide...
Datasheet
LT8630 on Analog.com
Hi keddy,
You must connect LT8630's GND, along with other external component with respect to -Vout.
If you follow that connection, your output voltage should be like this:
Hi Audison, Thank you very much!
BR,
Keddy
hi Audison, Can this part support positive input but provide negative output. alrhough LTSpice can simulate -10V output.coz my customer claim he follow above schematic to design his own board. but can only meausre -1V at output. what could be the possible reason?
Hi keddy,
Yes, you can configure this for negative output by following the typical application at page 19 of the datasheet. Kindly provide the actual schematic, and some scope shot so we can dig further with the issue. Thanks!
