Cannot generate -5V from 6V with LT8362 and LT3091
I have an issue with my power supply tree:
6V -> LT8362 -> -6V -> LT3091 -> -5V
When I power on my board and I enable the LT3091:
- the LT8362 output is oscillating (dc=-5.5V, ac=1.5V)
- the LT3091 output is noisy
Please find above my schematic
- the schematic works well with LTSpice
- the LT8362 works well and generates -6V when the LT3091 is disabled
- the LT3091 works well  when I supply the -6V with a lab power supply.
Any thoughts ? It would be very appreciated.
Thank you !
Parents
    on Feb 18, 2021 11:55 PM
    Hi avasygn,
    I run simulations on your Inverting converter. Have you tried simulating using lighter load? I tried simulating from 750mA to 1.5A and it seems that it is stable at 850mA. The converter can reach at -6V, 1A but there is an increasing oscillation, which could possibly shut down your Inverting converter (Current limit).
    At 1.5A, it cannot sustain -6V and drops around 4.5-5.5V, therefore you're reaching dropout stage. This is the reason why you are seeing noisy output at LDO.
    This simulation below runs at -6V, 7 Ohm load.
Reply
    Hi avasygn,
Children
No Data
