I will be using LTM8020 to convert a 35 volt rail into a 1.8 V supply. As there aren't other voltage sources available and Vout will be below 3V, I need to use a voltage divider to derive the 3+ volts needed for BIAS from the 35V rail. How high can I go as far as resistor values for deriving this BIAS pin voltage? This is a micropower design and I'd like to waste as little power as possible with the voltage divider.
Thanks and Best Regards!
