To whom may it concern,
I'm HS.
According to the datasheet of LT8612, the device will be ON when EN/UV is applied with HIGH and shutdwon when it's connected to GND.
But the datasheet doesn't explain how LT8612 will work when this EN/UV Pin is floating.
This pin might be floating In my application. So i would appreciate if you explain this pin can be floating and how it will work when it's floating.
If this pin must needs pull-up/down, please recommend me the proper value of resistor.
Thank you!
