Hello I have a circuit which requires 10V DC supply. However, I have only 5V DC input and I am planning to use LT3959 for 5V to 12V conversion with SEPIC configuration and than use LT3086 LDO for converting it to cleaner 10V DC. Is it meaningful? if not, can you give me some advice? I am not sure about 5V to 12V conversion step since the convert ratio is more than two. I also need to know how much current LT3959 can give me in that configuration. LT3959 datasheet does not give detailed information about current capability of the LT3959 for different in/out voltage configurations.
Thanks in advance
