NTC function is described in the datasheet as follows.
would you teach how LTC3650 detect NTC pin unconnected. what is the threshold voltage to detect unconnected during sourcing 50uA?
How large additional resistor can I add to NTC pin to increase the effective temperature threshold?
---- description in the datasheet -----------------------------------------------------
If the NTC function is not desired, leave the pin unconnected.
The NTC pin sources 50µA, and monitors the voltage dropped across the 10kΩ thermistor.
If higher operational charging temperatures are desired, the temperature range can be expanded by adding series resistance to the 10k NTC resistor.
Adding a 0.91k resistor will increase the effective temperature threshold to 45°C.
