I want to know if the ADM8829 will work well with small MLCC capacitors instead of electrolytics. Datasheet recommeds ESR < 0,2 ohm and my MLCC candidates have <5 mOhm. I Want to generate -5V from +5V. Will there be any problem?
David
Strong EMC design
ADM8829
Production
The ADM8828/ADM8829 is a charge-pump voltage inverter which may be used to generate a negative supply from a positive input. Input voltages ranging from...
Datasheet
ADM8829 on Analog.com
David
Hi David,
There shouldn't be any problem with this. It is actually better to use a lower ESR capacitor because it contributes to the Rout of the part which greatly affects efficiency.
Doc
