The problem about the parallel output of LTM4671
hi all:
Now I am using LTM4671 to generate three power supply for FPGA: 1.2V, 2.5V and 1.8V; the configuration of the LTM4671 is as follow:
VOUT0: 1.2V
VOUT3: 2.5V
VOUT1 and VOUT2: 1.8V
My circuit schematic is refer to Figure 31 of the datasheet.
1)Tie VOUT1 and VOUT2 together
2)Tie VOSNS1+ and VOSNS2+ together and link to VOUT1 and VOUT2;
3)Tie FB1 and FB2 together, and use the 30.1K resistance downlink to GND;
4)Tie COMP1 and COMP2 together;
5)MODE/CLKIN12 float;
The VIN is +12V.
From the datasheet, if the RFB = 30.1K, the output = 0.6*(1+60.4/30.1)=1.8V, but now the actual output is 1.2V
If I change the RFB to 15.51K, the output will be 1.82V;
The outputs of VOUT0 and VOUT3 are OK..
Why?
Thanks!
Best wishes!
