LT3086 soldering recommendations
Hi All,
We are using LT3086 in our application to generate different output voltages. Load current is < 20mA. We are observing issues at the output.
1. Output voltage generated is less than desired voltage.
2. Sometimes output voltage regulates well. After sometime, output voltage drops to less value.
We had to manually solder these ICs. Is there any special instructions for manual assembly of these ICs?
We wanted to rule out any soldering issues and hence request you to please provide us with necessary assembly/soldering instructions. Is RoHS solder ok?
Thanks
C.Pradeep
