LT3045 output isolation with LC-filter or ferrite beads
I have several chips powered by LT3045 that requies power-line isolation. Usually we can use Pi-type LC filters or ferrite beads with some capacitors on each chip's power-in port. As LC circuit can resonate on specific frequency, we usually put a large capacitor series with a small resistor to increase the ESR to do zero compensation.
But I noticed on LT3045 datasheet P16, it says "Therefore, it is very important to avoid adding extra impedance (ESR and ESL) outside the feedback loop."
I don't quite understand why we should avoid adding extra ESR outside the feedback loop. Do these LC filters or ferrite beads in my application makes LT3045 unstable and break the output?
    on Oct 28, 2020 6:00 PM
    I think you raise a good point.  I will double-check with the design group to see if they did not mean "... inside the feedback loop."  I did an experiment in the lab just now.  I did a load transient test with the standard LT3045 demo board and then I repeated the load transient test with a ferrite bead-capacitor filter added right at the output terminals.  My experiment showed that the stability indicated by the load transient test did not change much when I added the output filter.  I show the scope captures with conditions and schematic in the images below.
    Conditions:  LT3045EDD, DC2491A, 5VIN, 3.3VOUT at 200mAy to 400mA to 200mA, VCOUT IOUT load trans_0.bmp
    Conditions:  LT3045EDD, DC2491A, 5VIN, 3.3VOUT at 200mAy to 400mA to 200mA, filter out, VCOUT IOUT load trans_0.bmp
  • Thank you so much for your detailed experiment results. So it seems like a typo in the datasheet?
    That makes me relieved, thank you
