LT1944: output voltage fixed multiple of input
The user inquires about using the LT1944 to achieve a 16V/10mA output and a second output that is 1.5x the input voltage (3-4.5V) with a max current of 100mA. The final answer indicates that the current limit of 250mA makes it impossible to achieve 16V/100mA from a 5V input. The user is advised to use LTspice to verify design changes or consider other boost regulators. Relevant Analog Devices products: LT1944, micropower boost regulators.
I am working on a design using LT1944, with input of 2-3V and the first output of 16V/10mA max.  The second output I would like to set at a fixed multiple of the input voltage (1.5x), so it varies from 3-4.5V according to the input.  Max current from that output would be 100mA.  So in essence, not unlike a charge pump function.  Would this be possible?
Jon
