LTC4266 Fault Delay time
hi,
   For the application of ltc4266, I need to change the fault delay time which is from icut fault to next detect to 10 seconds. How should I set it? Is it from the register?
thank you!
Deleted "Issue" in the subject line. There is no issue. The request is for a customer fault delay timing.
[edited by: dreyeslt at 3:21 PM (GMT -4) on 29 Sep 2020]
Top Replies
  • The LTC4266 may be configured via the I2C interface to Semi-auto mode operation.  The detection can be enabled in your specified time.
  • ADI PoE PSE software files are available for request on Analog’s Software Request Form (http://analog.com/srf).  Fill in the Software Recipient Information and Commercial Information.  In the Software Requested section, select Power over Ethernet in the Target Hardware drop down list and then select the software file(s) for request for the appropriate PSE controller.
    LTC4291 PoE PSE
    LTC4291 Production Firmware (device firmware)
    LTC4291 Semi-auto Demo Software (Semi-auto operation software)
    LTC4291 Software Interface Datasheet (software interface and register map details)
    LTC4271 PoE PSE
    LTC4271 Software Interface Datasheet (software interface and register map details)
    LTC4266 or LTC4274 PoE PSE
    LTC4266 Software Interface Datasheet (software interface and register map details)
    LTC4274 Software Interface Datasheet (software interface and register map details)
    LTC4266A/C or LTC4274A/C PoE PSE
    LTC4266A/C Software Interface Datasheet (software interface and register map details)
    LTC4274A/C Software Interface Datasheet (software interface and register map details)
