Hello all,
Regarding the LTM8002 Recommended PCB Layout, I wanted to know if the following components layout is acceptable (compared to the recommended datasheet layout):
Pros:
1- Output capacitor ground return path loop is much shorter than the recommended layout
2- Signal ground is more isolated from power ground (connected only to A7 pin)
Cons:
1- Feedback resistor is placed at bottom layer, and the resistor connection to ground is a bit longer - can it cause problem?
Can someone say why I shouldn't use this layout?
Thanks!
Nir
Edit Notes
.[edited by: Nir76 at 1:00 PM (GMT -4) on 28 Sep 2020]
