Usage of ACSNS pin on adp1046 LLC Half bridge resonant mode.
We have delevoped an evaluation board based on ADP1046 Half bridge resonant mode LLC converter according to UG-768 Analog Devices EVB schematics but for application . same as stated at the UG-768 documentation we use PWM outputs for controlling the SR . And we use ADP1046ADC1-EVALZ  board to control the converter.
We have noted that if we connect ACSNS pin according to UG-768 (not connected ) the converter is not stable it skips frequencies and stop from time to time even when all flags are disabled.
we tried to connect it according to Figure 19. Feedforward Configuration from adp1046 datasheet the controller seems to work stable but this connection is not recommended for our topology as stated at Figure 62. Resonant Synchronous Rectifier Control Circuit page 82 of adp1046 datasheet .
What is the correct usage and connection schematics and function of ACSNS in half bridge resonant mode.
Best regards.
Roman
Parents
  • Thanks a lot for the Info.
    I have one more questions.
    I want to use ADP1046A for the battery charge application. Please see the below details for CC mode operation.
    In battery charger application, CC mode plays the major role until it crosses boost/bulk mode level. So please help how i can implement CC mode in ADP1046A. What are all the parameters to be updated in the tool.
    Thanks
    Sureshkumar P
Reply
    Thanks
    Sureshkumar P
Children
No Data
