PCN_031418 tells new die will be shipped with code 1805.
My question is whether the previous version will work properly or not? eg. 343MY version?
And why PCN notes can not be found on offical site?
(I had a lesson with LTC3639.... )
Thanks!
LT8630
Recommended for New Designs
The LT8630 is a current mode PWM step-down DC/DC converter with internal synchronous switches that provide current for output loads up to 0.6A. The wide...
Datasheet
LT8630 on Analog.com
LTC3639
The LTC3639 is a high efficiency step-down DC/DC regulator with internal high side and synchronous power switches that draws only 12μA typical DC supply...
Datasheet
LTC3639 on Analog.com
Thanks!
Hi iotYou,
I think that you need to request a copy of the PCN through website or through a local ADI FAE or representative. The previous LT8630 should work properly.
