we are looking for LED Driver IC with following requirements
1.pure current controlled (Analog based ) LED driver
2. it should be non-switching regulator type LED driver to suppress switching noise.
3. input is 5V. we do not need more than 5V supply for LEDs.
4. input is PWM.
5. we can controll each channels of LED driver by programming.
6. required minimum 3/4 channels.
7. LEDs should glow off completely , when we give zero duty cycle of PWM.
8. Maximum current per channel should be at 100mA.
9. it is used in medical endoscopy. so LED driver should have camera application. not back light LED driver.
10. should have medical standard.
11. For white balancing, we need each channel control through programming
12. Maximum LEDs per channel is 3. So LEDs in a channel can be 1/2/3.
Edit Notes
Maximum LEDs per channel is 3. So LEDs in a channel can be 1/2/3.[edited by: ameenu at 11:53 AM (GMT -4) on 26 Aug 2020]
