LT3081
Recommended for New Designs
The LT3081 is a 1.5A low dropout linear regulator designed for rugged industrial applications. Key features of the IC are the extended safe operating area...
Datasheet
LT3081 on Analog.com
LT3090
The LT3090 is a 600mA, low dropout negative linear regulator that is easily parallelable to increase output current or spread heat on surface mounted boards...
Datasheet
LT3090 on Analog.com
LT3089
The LT3089 is an 800mA low dropout linear regulator designed for rugged industrial applications. Key features of the IC are the extended safe operating...
Datasheet
LT3089 on Analog.com
Hello
Now I'm working on development using the LT3081 and LT3090.
It is a simple circuit in which the input voltage to the SET pin of LT3081 and LT3090 is output to Vout (Vout = same to SET pin voltage).
I have something curious about my circuit now.
In the picture above, I would like to know the proper resistor values of R7 of LT3090 and R9 of LT3081.(Simulation is no problem with 49.9Kohm.)
Is there any problem with the resistance of SET pin??
If you know, please recommend the resistance value.
Have fun~!!!
Thanks for the post. Avoid driving SET away from OUT as I discuss in this post titled "LT3083 output not zero when set pin grounded.".
Thank you for your reply.
But, I don't understand your replay.
what does mean "Avoid driving SET away from OUT"??
Just, I want to (SET pin Voltage = LT30XX's OUT pin Voltage).
So, Is there no need for the resistor of the set pin??
Or is it okay to put it with a 49.9Kohm resistor?
