ADM1270. Is there are any restrictions to use this controller in N 1 power redundancy?
ADM1270. Is there are any restrictions to use this controller in N+1 power redundancy?
In datasheet I found no details about pull-up pull-down mechanics in gate control of Q1 & Q2.
Only found such parts:
An undervoltage event is detected when the voltage
connected to the UV pin falls below 1 V, and the FET is turned
off using the 10 mA pull-up current. Similarly, when an overvoltage
event occurs and the voltage on the OV pin exceeds 1 V, the
FET is turned off using the 10 mA pull-up current.
Current sources in GS of Q2?
When VCC is connected to the input supply, the internal supply
(VCAP) of the ADM1270 must charge up. VCAP starts up and
settles in a very short time. When the UVLO threshold voltage is
exceeded at VCAP, the device emerges from reset. During this first
brief reset period, the GATE and TIMER pins are both held low.
LOW to WHAT?
or just shunt Vgs of Q2 to zero voltage drop?
Thanks!
