Dear Sir/Mamm,
I have a question two condition of LTC3886-1.
I want to know how the register setting changes in both cases of LTC3886-1.
1. When using four independent channels of output:
2. To combine outputs into one and use four outputs,
I will use the parameter values set below.
Command Name |
CMD CODE |
SET VALUE |
MFR_CONFIG_ALL_ LTC3886 |
0xD1 |
0x21 |
MFR_PWM_MODE_LTC3886 |
0xD4 |
0x81 |
OPERATION |
0x1 |
0x80 |
ON_OFF_CONFIG |
0x2 |
0x1E |
VOUT_OV_FAULT_ RESPONSE |
0x41 |
0x47 |
VOUT_UV_FAULT_ RESPONSE |
0x45 |
0x47 |
IOUT_OC_FAULT_ RESPONSE |
0x47 |
0x87 |
TON_MAX_FAULT_ RESPONSE |
0x63 |
0x80 |
OT_FAULT_RESPONSE |
0x50 |
0 |
UT_FAULT_RESPONSE |
0x54 |
0 |
MFR_FAULT_RESPONSE |
0xD5 |
0 |
MFR_PWM_CONFIG_LTC3886 |
0xF5 |
0x90 |
Others |
Default |
