Question for your ADP5062 again
Can anyone expert  reply about this?
This sled seems to broken, so I put this again here.
Thanks
Dear Sir/Madam,
Our customer is studying with your power ADP5062.
So he has brought as following questions. I needs your good comment here thanks.
Q1)
Your datasheet Interrupt Enable Register Address 0x09 on table-27 shows that defaut setting is all=0 it means disable.
Question does this means that like if we put 0 at "EN_THERM_LIM_INT", then the current of charging is no limitation even if die temp heat more than TLIM(115C) temp correct?
Q4)
If we dont use SYS_EN, so how should we deal this pin what is open-drain. No Connection is correct? Otherwise connect it to GND?
Q7)
Does AD5062 have the current limit function for shorting between ISO_Sx pi to GND.
eg; open the internal FET
Thanks Kaos
