ADD5211 power on
Dear Sir/Madam,
I`m using the ADD5211 to drive a LCD backlight, but sometimes (very rare) it doesn´t power on.
After connecting the EN-pin or the UVLO-pin shortly to ground it starts again.
Unfortunately I didn´t connect the Fault-pin, so I can`t monitor any fault state.
I tried to connect EN-pin or UVLO-pin via a 100kOhm resistor to VIN, but without any success.
I can also reproduce it by permanent powering the ADD5211 and switching off/on the EN-pin.
I already ordered the evaluation board and use quite the same values for all components,
but could not reproduce the faulty behavior.
Production date ADD5211: 1319 @ADD5211-Evalboard and 1634 in my design
Any idea?
Many thanks,
Sven
    on Jul 5, 2017 8:27 PM
    Hi Sven,
    The only latched fault conditions causing the ADD5211 to turn off are LED short or LED open, these can also be indirectly triggered by another condition such as in-rush current. Since you could replicate the issues by repeatedly enabling and disabling the part I would exclude connection issues with the backlight.
    Could you please let me know the following:
    - Is LSD pin biased as suggested in the datasheet or tied to VDD? If biased, could you try to force it to VDD and see if the problem goes away? I am not suggesting this as a solution but to isolate the origin of the issue.
    - How many LEDs, color and strings are used in your application?
    - Could you confirm the values for the passive components used and the input supply voltage?
        -> I would need the exact p/n for COUT, L1, D1, Q1, Rcs and Css
    - If needed, would you be able to probe the FAULT pin together with VOUT with a two channels oscilloscope?
    Maurizio
  • Hi Maurizio,
    thank you for your quick answer and your guidelines.
    First I figured out that the FAULT pin stays high under fault condition.
    After I found the main different between my circuit and the eval board.
    *** 100nF for emc reasons between U_out and FB ***
    Without the capacitor the ADD5211 works well!
    Thank you again and best regards,
    Sven
    on Aug 2, 2018 3:52 PM
    Thank you,
    EZ Admin
