ADP5070 synchronization
Is it possible to synchronize two ADP5070 without using externally generated signal? Just something like connect pins SYNC tohether with resistor to ground or Vcc to select 1,2 or 2,4 MHz?
I didnt find this information in datasheet. It is must for reduction of low frequency switching noise due to nonsynchronized ICs.
Thank you in advance
