Hi
Suggest a regulator which can generate 450V output with 1mA output current from a source with minimum 5V to maximum 12V input.
Regards & Thanks
Bivin George
Hi Bivin,
I cannot get an existing solution but you can work with local ADI support to understand more your application.
You can check reference document in link below to achieve higher boost factor by using cascode connection.
https://www.edn.com/design/analog/4368842/Use-a-boost-regulator-beyond-its-rated-voltage
Hi Bivin,
You are get the LTspice files in LTC website.
About the regulator, please check ADP1612/13. Datasheet and design tools are available in website.
You may also take a look at application note AN-1126.
Hello Bilvin,
have you checked out the LT3751 yet?
Linear Technology - Product Page
Its intended to charge capacitors to large voltages and offers plenty of power as controller. When 450mW is all you're asking for the integrated parts like LT3484 could be worth a look, too:
Hello i have a problem with this 400V output design
My problem is; i can not find the transformer (''13324-T087'' by Sumida Corporation,) in digikey, rs component, mouser or any other..
I need to buy not 200 pieces, just 5 or 10 piece.
Is there anyone can help me to cover that problem, i will change my whole design if i can not find this component.
