Need Help for LTC7004
We are using above circuit for 48V load ON/OFF control
We are facing one problem if i am enable INP pin through micro controller i got 48V as output
If i am disable INP i got 11.5V as ouput.
But i am connecting 10K resistor on MOSFET sorce  side with respect to GND,now i got 0V as output
Why i am getting 11.5V floating voltage as ouput??
I can't understand below point in datasheet,Can you explain it?
TS (Pin 8):Top (High Side) source connection or GND if
used in ground referenced applications
Can you give me solution for above points?
Parents
    on Jan 20, 2018 5:51 AM
    The LTC7004's internal charge pump supplies current out of the BST pin to charge/maintain voltage on the BST-TS capacitor. This small current is likely why you are seeing the TS pin float to 11.5V when TS is unloaded.
    The Pin Function description "TS (Pin 8): Top (High Side) source connection or GND if used in ground referenced applications" on page 6 of the LTC7004 Data Sheet means that the TS pin is (typically) connected to the source the external MOSFET in high-side applications or to GND in ground referenced (low side applications) applications. Low side applications are when you are using the LTC7004 to drive a low side (source connected to GND) MOSFET.
Reply
Children
No Data
