LTM4649
Recommended for New Designs
The LTM4649 is a complete 10A high efficiency switching mode step-down DC/DC μModule® regulator in a 9mm × 15mm × 4.92 BGA package. Included in the...
Datasheet
LTM4649 on Analog.com
LTM4622
The LTM4622 is a complete dual 2.5A step-down switching mode μModule® (powermodule) regulator in a tiny ultrathin 6.25mm × 6.25mm × 1.82mm LGA and...
Datasheet
LTM4622 on Analog.com
Hi
Regarding LTM4649 and LTM4622, I'd like to know Vout start-up time(t1) after reaching RUN pin ON threshold and Vout turn-off time(t2) after falling RUN pin OFF threshold.
Hiroyuki
Hi Hiroyuki,
Regarding this delay, when the RUN threshold is reached INTVCC gets enabled and once it reaches its UVLO threshold it waits for a number of clock cycles before switching starts. For practical values of soft-start cap you will find that the SS voltage will reach tens of mV (ie 50mV) before you see switching begin and Vout ramp up. You can also look into this in more detail with LTSpice simulations for these parts.
Thanks.
