LTC4066 terminate charge cycle
Why does the LTC4066-1 ONLY stop charging when timer expires, and NOT when CC/10 is below a certain threshold ?
(We now see that the LED is switched off, but charge current is still flowing into the Li-Ion cells, until the timer expires)
Is there a good reason to do so ?
Is there a similar device which stops charge cycle at CC/10 threshold ?
Thanks for your reply,
WKR,
Eric C.
  • Generally speaking, when the charging rate of a charging cell drops to one-tenth the programmed charge rate, the cell is within a few percent of being fully charged, and is ready for back-up support.  This indication can be useful even though the battery is not fully charged.  The timer serves as one layer of protection against overcharging a cell.  Additionally, the LTC4066 has a recharge threshold; charging resumes when the cell voltage drops below VRECHG (~100mV below 4.1V for the LTC4066-1).  The combination of the constant-voltage charging at lower charging current and the VRECHG ensures the cell will always be within 0.1V of fully charged.
    The LTC4055-1 uses a different scheme.  The \CHRG pin is asserted whenever charging is taking place.  Charging is terminated when the timer times out; at that point, if the voltage is less than VRECHRG below the final charged voltage (4.1V for the LTC4055-1), the timer is reset to 0, and charging resumes.
    To contrast the approaches, in the LTC4066 \CHRG is negated during charging when the cell is, for most intents and purposes, charged.  The LTC4055 asserts \CHRG as long as the cell is charging, regardless of charging current.  This app;roach obscures the fact the cell is de facto charged and ready for use even though the timer may not have yet timed out.
    Depending on the requirements of your application, the LTC4055 may be the preferred approach.
    Thank you,
    EZ Admin
