what will happen if an external voltage is applied to VOUT of the LT3083, that is greater than the voltage at the SET pin, but smaller than the voltage at VIN?
What will happen if an external voltage is applied to VOUT of the LT3083, that is greater than the voltage at the SET pin, and greater than the voltage at VIN?
LTSpice simulation shows that the LT3083 will block any voltages externaly applied to VOUT, no reverse current is flowing from OUT to IN, SET or Vcntrl. Is that true?
Regards, Niels
