Can the LT8609S (Silent Switcher) be used in an inverting buck-boost topology?
I am trying to utilise the LT8609S in an inverting buck-boost topology to generate a negative voltage rail (-5V) from a 4.5-5.5V input voltage supply
The reason for using LT8609S is due to it being a "Silent Switcher" part (reduced EMI). Unfortunately when I simulate this in LTspice, the output voltage is not the expected -5V (closer to -4V).
Is this a limitation with the spice model of the LT8609S or is it indeed that the part cannot be used in this configuration?
LT8609S Inverting Buck Boost circuit
Output voltage
Parents Reply Children
No Data
