September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
ADP7183
Recommended for New Designs
The ADP7183 is a complementary metal oxide semiconductor (CMOS), low dropout (LDO) linear regulator that operates from −2.0 V to −5.5 V and provides...
Datasheet
ADP7183 on Analog.com
Hi
I can't find the maximum operating voltage on the ADP7183's EN pin in the datasheet. I see that the absolute maximum voltage is +5.0 V but what is the operating maximum voltage?
Regards, Jonas
Less than maximum rating.
As the threshold is much lower, there is no need to approach maximum rating.
Use a resistor devider for EN input if neccessary.
Hi Jonas,
You may operate the EN between +5V to -5.5V. Just make sure you won't exceed the absolute maximum ratings.
Best Regards,
Alex
