LTC3786 Solution for Mosfet
This is Sreenath, and I was going through the datasheet of "LTC3786", and I had a look for the high efficient boost converter application diagram using DRC attached.
So, the question is that, in the application diagram I saw that there are 2 MOSFET's present (RJK0305), so can I use one MOSFET in place of two ?
And will it encounter any problem?
Secondly, if I for instance want to change and use FDS7760A?
Actually I want my PCB board to be Higher efficient and less prone to heat, with Minimal components.
My Needs -
7.4V to 8V input
24V Output at 3 ~ 5A
Application -
Will be using it in a Sealed Audio Amplifier Enclosure.
Thank You!
Sreenath ChatterjeeApplication Diagram.
