Can you provide an example or some reference design aobut the ADP3654 driver?
I want to use it to drive two separate P-Mosfet in an high side switch application (+8V and +5V).
thanks
thanks
Hi
ADP3654 is a N-MOSFET driver. I would recommend looking in to LTC1693-5
https://www.analog.com/en/products/ltc1693-5.html#product-reference.
You could use the circuit on page one of the data sheet at reference
this is hte simple circuit I have in mind
the output stage are totem pole, why it should not work?
thanks
Hi
You could try the configuration, please note that the logic would be inverted when using a PMOS
Regards
