Are LTC4162EUFD-LAD and LTC4162EUFD-LADM identical?
I made a battery charge board using  LTC4162EUFD-LAD. At moment the code LTC4162EUFD-LAD is difficult to find on the electronic market so I would like to use the chip code LTC4162EUFD-LADM . Are they identical?
I read the datasheet and I found the follow descriptions:
  • LTC4162EUFD-LAD              I2C Adjustable Voltage
  • LTC4162EUFD-LADM           I2C Adjustable Voltage MPPT ON
What it means? Any differences? In my application I reset via firmware the MPPT bit in order to disable the MPPT algortihm.
Can I still disable via firmware the MPPT algorithm in LTC4162EUFD-LADM ?
I need to charge lithium battery ( 2 cells) with a charger 12 Volt/2 A .
Thank you.
Gaetano
