LTC2991 current measurement with voltage divider
I am studying the following voltage divider circle in LTC2991 for current measurement. I have a question for the current measurement LSB value. Appreciate any advice.
As I understand, the voltage divider will divide differential voltage in 0.01 ohm. If LTC2991 Differential voltage is 19.075μV/LSB, the differential voltage LSB across 0.01 ohm (with voltage divder is 71.5K top resistor and 10.2k bot resistor) will be 8 x 19.075μV= 152.787μV/LSB.
In calculation, the circuit current measurement should be 152.787 / 0.01 = 15.27mA /LSB. However, the datasheet is 15.54mA/LSB. Slightly different.
Might I know if any problem in my Calculation? Appreciate if any advise.
Thank you.
Mark
