I was considering using one of these linear regulators to power and LED. I was wondering if the SHDN pin reacted fast enough to act as a PWM input at, say, 100Hz.
Dave
LT3010
Recommended for New Designs
The LT3010 is a high voltage, micropower low dropout linear regulator. The device is capable of supplying 50mA output current with a dropout voltage of...
Datasheet
LT3010 on Analog.com
LT3012
The LT3012 is a high voltage, micropower low dropout linear regulator. The device is capable of supplying 250mA of output current with a dropout voltage...
Datasheet
LT3012 on Analog.com
Dave
If you are referring to one application on the datasheet (page15).
This application for the part can't be used for a PWM input but only for a "Constant Brightness" of LED (Constant On/Off only).
If you are looking for an LED driver. We have a wide range of LED driver you can choose from depending on your specification.
See link below for you to search for the part/s you need.
https://www.analog.com/en/products/power-management/led-driver-ic.html
regards,
Ash
