LTM4686 MFR_CONFIG_ALL
After setting the output voltage with RVOUTnCFG and RVTRIMnCFG and starting up,
we plan to change the voltage with VOUT_COMMAND.
Is it necessary to change MFR_CONFIG_ALL [6] = 0⇒1b?
Even if I do not change, sending VOUT_COMMAND will change the output voltage
  • +1
    on Mar 11, 2020 4:10 PM
    Once power up , the output voltage can be changed via VOUT_COMMAND at any time.
    These changes will not be saved after power down when resistor respect configuration is enabled.
    To summary
    - When resistor configuration is respected, during power up, the resistor setting will be effective.
    It will also update the internal NVM values. Once power is up, VOUT_COMMAND can be changed real time.
    - When resistor configuration is ignored, during power up , the VOUT_COMMAND set internally at NVM will be effective.
    During power up, VOUT_COMMAND can be changed real time.
    If the value is saved into NVM, then after restart, the VOUT_COMMAND save in NVM will be effective.
    Please check datasheet about this for detail.
    Thanks.
