LTC3811 power stage transconductance - exponential behaviour
I'm trying to determine the power stage transconductance of an LTC3811 regulator circuit so I can design the compensation network. I made some measurements on an LTSpice simulation by applying various load steps and looking at the resulting voltage step on the COMP pin, and the results are showing that the transconductance is exponentially related to the value of the sense resistor. The graph shows my measurements, and I was able to fit an exponential curve to it and predict the transconductance at any sense resistor value reliably. This behaviour also seems to be very consistent regardless of load current.
Can anyone confirm if this is the expected behavior and not just a simulation artifact, because I would have expected a simple inverse linear curve? I do intend to verify this on a dev board at some point but I figured it was worth asking before I go buying hardware.
Tom
Parents Reply
  • Hi Mike,
    I think I've tracked down the issue. I was including some series inductance in my sense resistor in an attempt to make the simulation more realistic (and model the behavior of the sense filter properly). Turns out LTSpice gives all inductors a 1mR ESR by default. So my 1mR sense resistors were actually becoming 2mR, 2mR was becoming 3mR etc. When I manually set the ESR to 0R I get the expected response.
    Tom
Children
