Does the SYNC pin Phase Locked Loop synchronize to an edge? Does duty cycle of the SYNC signal affect the duty cycle of the converter?
Just wanted to check in on my question and see if someone was working on it. Thanks.
Yes, SYNC pin will synchronize to an edge. You may check this using LTspice.
Duty cycle of the converter will depend on input and output voltages as per equation on page 15 of datasheet.
