VIOS ,mode with LTC3416 and LT3071
The user inquired if the LT3071 can be configured to work with the LTC3416, given the VIOS mode's ability to regulate the output of most LTC switching regulators by sinking current from the Ith compensation node. The final answer confirmed that the LT3071 can be used with the LTC3416, and suggested using LTSpice for designing the compensation network, with bench testing recommended for optimizing transient performance. The user successfully simulated the combination in LTSpice, noting that the LTC3415 is similar but lacks a spice model.
The LT3071 datasheet provides a good description of the VIOS mode and an sample design using this device with the LTC3415EUHF.  The LT3071 data sheet (page 17) says "It typically regulates the output of most LTC switching regulators or LTM power modules, by sinking current from the Ith compensation node".   Does that mean VIOS can be configured to work with LTC3416?  This IC does have an Ith pin, but there is not really enough information in the datasheet to be certain this will work.   If this will work, its not clear how to tune the compensate newtork.   The LT3071 datasheet provides some useful specs on the VIOS output, but its not clear (to me) what the LTC3416 requires from the compensation.
