Per data sheet (p.9) of the LT3517, when the CTRL pin voltage is less than 1V, the LED current is: ILED =VCTRL/(10*RSENSE).
Question: What precision of this equation in temperature range of +10 to +50 Celsius degrees?
Hi Mrivlin,
We don't have readily available data so we need to test in bench. Can you share Estimate Annual Usage of the product to justify the activity?
Estimated annual usage for the LT3517 is 400k
Hi
Attached is the data gathered on Vctrl vs VISP – VISN Threshold
This was gathered using a DC1279A eval board
Regards
Thank you very much Mikee_Lacson_00 !
