I'm interested by the LTC4162-LAD to handle charging, powerpath and telemetry for a 4-cells 3Ah Li-Ion battery pack.
I have three questions :
- my battery pack will have (like most battery packs) an embedded circuitry that will cut off the output when cell voltage is below a specific level (2.4V/cell for example). How does the LTC4162-L reacts when it checks the battery ? I don't have details about the battery protection circuit but I guess there is a diode that allow incoming current to recharge the battery :) The LTC4162 battery check first consists in drawing a small current (1mA) from the battery, and this first test will obviously fail because battery voltage will be cut. After that the device starts a second test by charging the battery with a reduced charging current. That should wake up the protection circuitry, and I guess that the LTC4162 will detect the battery as being ok and will initiate charging (with preconditionning current). Can you confirm ?
- the batt draw quiescent current is about 60µA in standby (no Vin), because analog circuitry and power path charge pump are active. If I want to reduce this current to avoid shortening battery life (customers never read manuals, some of them won't recharge the product after using it, and may store it for some month before using it again), I imagined the following thing : when the product is turned OFF (ON operation is done by a pushbutton that enable power supply, then MCU will force power supply converters enable signal, and will release it (to go OFF) when pushbutton will be pushed again), since I control power supply by software, I would arm the ship mode and then turn off power. The BATFET body diode will still "power" my circuit and allow restart on request. If user plugs external power, the ship mode will be disabled, that's ok, but if user want to power on again the product without recharging it, the charger will still be in ship mode (telemetry will be unavailable and BATFET disabled). The only way to disable ship mode is to have VIN > 1V. Can I imagine sending a 3.3V pulse on VIN to disable the ship mode when I want to get back full powerpath efficiency and telemetry ?
- a last question about Rsnsb and current sensing, could you confirm following calcul : if I use Rsnsb = 20mOhms, the maximum charging current will be 1.6A (32mV/0.02), that is the max current allowable for my pack, but that also means that the maximum batt current consumption (drawn FROM the battery when not charging) that I could measure is 2.4A (16 bits signed => 15 bits absolute => max current measured = 32768 * 1.466e-6 / 0.02 = 2.4A. But if I decrease Rsnsb, I would be able to increase the current measurement range, but the default charging current will be higher than 1.6A, outside the specs...and if somebody makes a mistakes and plug the external power while the MCU has not been programmed (and so the LTC4162 loaded with default values), the battery will be overcharged... If I choose the safe way and use 0.02 Ohms (that's what I think I will do) : if current goes higher, does the ADC saturate and does not roll over codes ?
Thanks !
Aurelien
