LTC4001 Battery Charger
I have noticed that when the TIMER and /EN pins are grounded and the /CHRG pulled high through a pullup resistor (2K), the /CHRG pin oscillates at 10ms low and 20ms high.when a battery is absent.  Can I depend on this behavior for battery absent detection?  The data sheet does not describe this condition, but it is certainly useful if it is not just an anomaly.
  • Does the LTC4001 have any upper capacity limit, for example a fixed timeout of X hours? If not, I see no problem with your approach.
  • Take a look at the battery node voltage on a scope while this is happening. You should see a similar waveform. This is because, with the timer disabled, it is relying on current-based termination which is satisfied immediately when it starts charging. This causes the output to cycle as it continuously restarts charge cycles. This behavior is benign and reliable; you are welcome to use the /CHRG oscillation as a no-battery indicator.
    You can also change the blinking speed by adding more capacitance to the battery node. This will slow the battery "charge cycle" completion, resulting in slower toggling.
    Zack
