LTC7004 dV/dt imunity?
Hello everyone.
I tried to use LTC7004 to drive MOSFETs on a specific application: Drain/source of the MOSFET is not tied to a specific voltage. dV/dt is close to 40V/10ns.
I noticed that:
   - There is no dV/dt specified in the datasheet.
   - There is lot of capacitance added on the demo board DC2750A (100uF) without explanations.
When I try to simulate such dV/dt when the gate is already driven (INP=1, TG-TS=12V), there is lot of perturbations on TG-TS that can cross AMR (>16V) or go down and bad drive the MOSFET!!!
Adding capacitance to the ground as my voltage source dV/dt is weak imperance seems not usefull...
Is LTC7004 good for such dV/dt?
Do you have any suggestions to improve dV/dtimunity?
Should I use another isolated gate driver to avoid this?
I like LTC7004 for this low power consuption and static use. Standard gate drivers with charge pump generally use the fact the source is put to ground at duty cycle and I dont in my application. Isolated gate drivers is a good solution but power consuption is often high.
Thank you for your answers.
