There is a problem when I add a voltage doubling circuit in a DCDC boost circuit output with LT1618, help! Thank you.
I need help! Thank you!
1、My objective is: Design a circuit can boost 3.3V to 6V and 24V, then use voltage doubling circuit boost to 12V and 24V.
2、As shown below is my schematic and layout: I add a voltage doubling circuit in output, just like a circuit given by LT1613 datasheet.
3、At 0 load and don't add voltage doubling circuit, the circuit can run normal operation, and the output ripple just 600uV at 6V and 1.4mV at 24V.
BUT, as soon as I add the voltage doubling circuit, there is a 36.8Hz triangular wave at the condition of 6V appears on the screen and output is 12V current is 5mA, the second picture as shown blew is the wave blowed up.
The third picture wave is the condition of 24V and output is 48V current is 24mA, it seems normal.
    please clarify your objective, as it is a bit confusing. Is your input voltage 3.3V to 6V , and also 24V?
    Or, do you mean the input voltage range is 3.3V to 6V, and the output voltage is 24V?
    Also, please explain the output current you need, and why is it you need a voltage doubler.
    Cheers!
  • Thank you very much for your reply.
    1. My objective is input 3.3V then output 6V and 24V, then double to 12V and 48V. There is a NMOS as a switch, by changing resistance switch output 6V and 24V.
    2. The 48V is intended to as a Phantom power. Because LT1618 can't get to 48V, I use a voltage doubler.
    3. The output current about 100mA.
    The problem is when I use a low current as load, output ripple will become strange as shown in the picture above.
  • Repost from dulcevida:
    I don't know much, but, you are welcome!
    The LT1618 will not work for you, for your intended objective.
    I would recommend you switch to LT8364, and still use a doubler. The LT8364 has a 60V switch, but if you attempt to do 48V from 3.3V you will run into duty cycle limitations due to the high step up ratio.
    I recommend you set the frequency at 1MHz and use an inductor value between 2.2uH-4.7uH.
    Best Regards,
    DV
