The datasheet contains a lot of equations.
Many of them referring to a parameter VTH.
I can guess it is some sort of Voltage Threshold, but I cannot find any explanation of exactly what it is referring to.
The closest I get is an example (pg16) where it is set to 5V without any reference to what it is.
Please explain what VTH is referring to.
Best regards
Zippzapp
Hi !The term VTH refers to the typical threshold voltage of the MOSFET M1 (The pass MOSFET in your application circuit).
The following equation can be derived from the figure below by following the highlighted…
The following equation can be derived from the figure below by following the highlighted path:
Let me know if you have any further questions.
Best Regards,
Ritesh
