I need a ultra low noise power supply with power and sequence control. Can i use a LTC2973 with two LT3045 ultra low noise LDO for this?
LT3045
Recommended for New Designs
The LT3045 is a high performance low dropout linear regulator featuring LTC’s ultralow noise and ultrahigh PSRR architecture for powering noise sensitive...
Datasheet
LT3045 on Analog.com
LTC2972
The LTC2972 is a 2-channel Power System Manager used to sequence, trim (servo), margin, supervise, manage faults, provide telemetry and create fault logs...
Datasheet
LTC2972 on Analog.com
Yes, Just as long as EN/UV voltage of LT3045 reaches/exceeds 1.24V (EN/UV pin threshold:Rising) or higher to turn it ON.
And according to specs of LTC2972 Vout_en is capable of up to 15V. So I think there will be no problem using that combination.
thanks for your answer. My next question is: How can build the current monitor and voltage fine adjustment without decrease the performance by LT3045 (Noise, PSRR)?
With best regards
You can refer to the "Applications information" section of the datasheet. There you can find how to improve LT3045 perfomance in reference to noise and PSRR.
