There is no output voltage on both channels, but there is voltage on the output of powerGood. Could this be a consequence of a forgotten resistor on the Rfreq pin?
I don’t understand how PG can be, but there is no output voltage.
LTM4646
Recommended for New Designs
The LTM4646 is a complete dual 10A output switching mode DC/DC power supply. Included in the package are the switching controller, power FETs, inductors...
Datasheet
LTM4646 on Analog.com
I understood what the mistake was. Forgot to set 12V on CPWR.
You are right. CPWR provides power to control circuit and it needs to be connected to Vin. A frequency set resistor is also needed at the FREQ pin. DRVCC pin needs a 4.7uF decoupling cap that puts close to this pin.
